Benchrest practice
A place to discuss new ideas, thoughts, and chat about existing competitions.
Benchrest practice
Postby zunmik » Mon Jan 07, 2013 8:40 pm
Had some practice last day or two, tried target pistols & springers, results with all target pistols good especially the 6m & the Compact indeed results with the Compact pretty amazing should be interesting when i shoot benchrest comp (i hope), M. :wink:
Swiss Arms TG1,~ S.G.S Duo 300, P900 IGT,Stoeger XP4, etc, G0JVB ex G6MUI.
Postby pmh » Mon Jan 07, 2013 9:01 pm
Glad to hear you are well on your way.
When I discovered my front sight was loose, I put a single shoot into a blank part of a target, then adjusted on to it.
Using my rest I put three shots in virtually the same hole.
The tricky part, for me, is judging the centre of the target. If I only used my 6G for this event, then I'd adjust it for dot the i sighting.
As I use it for others, the POI is the POA.
Return to Competition Chat
