Anyone with a link to the S/N lookup for Walther LP53, other
Postby DFWdude » Mon Apr 24, 2017 10:51 pm
I have an LP53. The factory target is dated 18/8/58, and the serial number is 030806. The target indicates 1958 manufacture, but I would like to verify.
DFWdude
Re: Anyone with a link to the S/N lookup for Walther LP53, o
Postby Leonardj » Thu Apr 27, 2017 10:46 pm
According to my info, the date on your test target would be a very accurate representation of the manufacture/dispatch date.
"S/N - 025734 : Jan 1958 through S/N - 033105 : Dec 1958".
The barrel weight would have been a later addition.
I will add the pic that you posted and the serial number to my database. Thank you.
Postby DFWdude » Thu Apr 27, 2017 11:54 pm
Thank you so much, Len!
DFWdude
Postby wadcutter » Fri Apr 28, 2017 6:19 am
DFWdude wrote:Thank you so much, Len!
Hi I knew someone on the forum would be able to help you with this query. :clap:
Kevin
Diana Original 6G Pistol
wadcutter
Postby webley701 » Sun May 28, 2017 6:32 pm
DFWdude wrote:I have an LP53. The factory target is dated 18/8/58, and the serial number is 030806. The target indicates 1958 manufacture, but I would like to verify.
Surely the factory test target date must be the most precise record you'll find for your pistol?
webley701
Users browsing this forum: No registered users and 5 guests
