Hello and 78G questions
Justin
Post by Justin » Wed Apr 10, 2013 12:14 pm
Hi Joe,
Thanks for the advice with emptying the gas and offering to send over a copy of the owner's manual. I did get a manual with this (and the box and even the original SW pellet tins - with pellets!) but did the usual bloke behaviour of using the item before reading the manual. When I read it I saw that they said keeping C02 in it was recommended, so I'll do this in future. As someone who is used to Umarex guns though, it strikes me as odd. I wonder what the reason for that is.
Justin
Joe
Post by Joe » Wed Apr 10, 2013 3:05 pm
Where did it come from via airmail
Any problems importing
Justin
Post by Justin » Wed Apr 10, 2013 5:37 pm
I saw an advert. on Gunstar. The seller, Jose, is based in Spain and has sold a number of SW 78 and 79 G pistols, along with other classic C02 pistols. I went for this one rather than a cheaper one on Gunstar at the same time because I wanted the original box, manual and pellet tin. Gunstar seems better than Guntrader for classic airguns.
No problems with importing. It came via special delivery with a tracking number. Not sure what the Royal Mail policy is though on airguns.
Post by pmh » Wed Apr 10, 2013 6:10 pm
Royal Mail have to carry airguns by "law"; though they did, again, try not to during a recent attempt at changing terms and conditions.
Luckily they backed down after the number of complaints they received and a campaign by  the BASC.
That said, Ofcom didn't allow this the first time they tried, so I am not sure what prompted them to have another go!
wmp50075
Post by wmp50075 » Wed Apr 10, 2013 7:58 pm
looks like ian has the very same garage/range as me, and a tempest too!
mrto
Re: Hello and 78G questions
Post by mrto » Sun May 12, 2013 1:36 pm
Justin wrote:Hi all,
Glad I found this useful site!
I've just purchased a Smith and Wesson 78G. It is a later model with the non-adjustable trigger and the cocking knob only has one power setting, unlike the earlier version. I didn't realise the later ones lacked the 2 settings on the cocking knob and for some reason mine does have 2 points at which the knob may click into place. However, if you push it fully forward, to the second click, it then jumps back to the first point as the trigger is depressed. I wondered why this is so? If there is just one power setting on the cocking mechanism, why have 2 points at which the cocking mechanism may be clicked into place?
It seems to perform fine - I got around 50- 60 shots from 1 C02 capsule. Does anyone know if this is the normal range shot indoors in the warm?
When it arrived via airmail I could not open the screw plug in the pistol grip to put C02 in. I took it to a local airgun specialist gunsmith nearby (Knibbs) who told me it had C02 in it! They then, oddly, told me that was why it had been jammed and, equally oddly, told me they could not release the screw to let the C02 out slowly because it may 'explode'. I was told they were fully booked so I could not leave it to be repaired. I then took it to Shooting Supplies in Bromsgrove who fixed it in 5 mins for a fee of £2.30. They opened it with grips (Knibbs had tightened it up again too tight), a tiny amount of C02 hissed out, and then it was noticed a new O ring was needed, and one from an Airmagnum was fitted.
In future I'd like to get it serviced and wondered if anyone knew of someone able to work with these. Most people who deal in vintage airguns seem to have never heard of the 78 / 78G and think a Smith and Wesson must be an Umarex 5/686.
Cheers,
Justin
Hi Justin,
I have the same model of 78g as you and experience the same thing.If on cocking I allow the cocking 'lug' to over travel it seems to find a second position that it will stay cocked at albeit tenuously a good slap on the pistol grip is enough to unseat it.Short of stripping the gun to investigate I can only guess at the cause,but am sure it was never intended as a secondary position so I cock the gun and concsiously avoid this happening.They are great guns,powerful and accurate and I am sure you will anjoy yours.ATB
Mark.
Justin
Post by Justin » Sat May 18, 2013 3:10 pm
Hi Mark,
I've got used to the cocking device now! I took it to the range recently and a friend with a chronograph measured its power. With the screw turned to low power it ranged from 383 FPS to 385 FPS, and on high power it ranged from 399 FPS to 409 FPS. I keep the C02 in it as the manual instructs but it loses the gas after a couple of weeks.
I saw a 79G advertised on Gunstar. It would be nice to have the .177 version too, but I can't justify forking out £350!
Justin
gingernut
Post by gingernut » Mon May 20, 2013 9:55 am
Two things there.
Whilst it is nice to have both calibres they perform much the same, and that is a silly Gunstar price!
