Spring pistol plink
Most of my shooting practice rifle or pistol is target based, but today after some heavy duty gardening i was to knackered for concentrated shooting so i dug out the recoiling springers for a plink, as usual did'nt get on with Falcon so i went to the Jumbo Lux, its got a shorter trigger pull that suits me better i also like the reach to trigger on this pistol, its got a short sightline so you need to get your target picture well prior to release, and from distant memory (about 30 yrs ago) you need a medium firm hold to get consistent results so i must give this pistol more use for its a fun gun to shoot, M. "link to pics for those unfamiliar with this pistol"
https://picasaweb.google.com/mickson33/ ... 5569298482
I used to use an old fashioned metal bread bin lid permanently open, a piece of thick carpet dangling @ the back, then a steel rod through the top @ the front with various targets dangling from the bar 25-45mm diameter, ie homebrew spinners, M.Ian:2700 wrote:Good call Mick
My project for tomorrow is to make some garage plinking targets. I have some large cardboard boxes that I am going to cut a large window in and add some suspended items inside.
Dangled teaspoons make a good plinking target.
I do have a set of Daisy metal silhouette targets somewhere. They really do go flying though. In the past, many fastener thematic a length of wood with a piano type hinge.
The Baikal MP-53M is a very worthy pistol. Very light weight and easy to cock. You should try one of four a springer, well worth the £50 or so.
I do want to have a go with a Jumbo. Always been a quirky gun which catches the eye.
I did enjoy my quick session with the Webley Tempest. I need to dig that out and have another go.
I also need to work on the trigger of the Predom.
If anybody has a cheap trigger shoe they want to get rid of, let me know.
I would like another Baikal 53m, but i want the the original one with the brown target grips, these pistols are very easy to tune & respond very well, the newer ones have better sights, but sporting grips, M.pmh:2703 wrote:Dangled teaspoons make a good plinking target.
Well I have quite a selection of these:
http://www.ebay.co.uk/itm/261041775060? ... 1439.l2649
going on. I really don't get how they can make, coat and ship these for a little over a fiver.
I am getting quite good with the Drulov and I can get two out of six "offhand" quite regularly.
Very cheap indeed.
>These< are a good buy, but he does tweak his prices a lot. They were £2 cheaper a week or so ago, and even more at Christmas.
Ive had one these for a while - a great bit of kit. The only downside is that lower power pistols cant hit the central reset target with enough force to make it operate properly. I dont have too much of a problem with resetting it manually though!pmh:2720 wrote:Very cheap indeed.
I put layers of tape over the magnets on resets until I find the amount needed to allow re setter to release. ATB. Pete.Ian:2722 wrote:Ive had one these for a while - a great bit of kit. The only downside is that lower power pistols cant hit the central reset target with enough force to make it operate properly. I dont have too much of a problem with resetting it manually though!pmh:2720 wrote:Very cheap indeed.
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it in a fruit salad. Gamo PR45, P17s, 1377, SMK rifle, HW 40, HW 45, HW 75, Gamo AF10, Hatsan mod 25, Tanfoglio Witness, Crosman 357, Browning Buckmark. Webley tempest. John Beatie holsters.
peteswright:2726 wrote:I put layers of tape over the magnets on resets until I find the amount needed to allow re setter to release. ATB. Pete.Ian:2722 wrote:Ive had one these for a while - a great bit of kit. The only downside is that lower power pistols cant hit the central reset target with enough force to make it operate properly. I dont have too much of a problem with resetting it manually though!pmh:2720 wrote:Very cheap indeed.
I never thought of that!
Excellent tip.
