[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4429: ob_start(): output handler 'ob_gzhandler' conflicts with 'zlib output compression'
Classic Air Pistol Association • View topic - fettling gamo compact trigger
Re: fettling gamo compact trigger
Postby Tank » Sat May 04, 2013 8:40 pm
micawber:2776 wrote:I think I will try some luminous pant used on fishing floats first just on the front sight, I have white paint on my beeman p17 and it seems to work best when it is on the front sight with the back unpainted.
That would work fine. In fact I have used Tippex on a front blade with some degree of success. It is a nice bright white and comes off easily too.
Postby micawber » Sat May 04, 2013 8:45 pm
Good idea, I never thought of that, I'll try that first.
micawber
Postby pmh » Sat May 04, 2013 8:47 pm
Humbrol model Paris are good too.
A cocktail sick leaves a nice dot.
Postby Tank » Sat May 04, 2013 9:20 pm
I use watch and clock oilers like these:
http://www.ebay.co.uk/itm/Oil-Pins-for- ... 4172bd09bd
as I find they are a little more precise. But that is just me. Nothing wrong with a cocktail stick.
Postby micawber » Sat May 04, 2013 9:58 pm
I've got a load of cocktail sticks so I'll try those first.
micawber
Postby Tank » Sat May 04, 2013 10:08 pm
micawber:2789 wrote:I've got a load of cocktail sticks so I'll try those first.
:D
I hold my hands up and confess to over complicating things on occassion!
Postby Spiny Norman » Wed Feb 15, 2017 9:56 am
micawber wrote:Well guys I finally finished fettling my gamo compact trigger, First I striped down the trigger mechanism smoothed and polished all the moving parts with a fine file and finished with 1200 grit wet and dry (the surfaces were pretty rough) then assembled it all with a touch of molly grease on the moving parts, I kept the original springs, I then replaced the trigger adjusting screw with a longer one from a light switch wall cover, (the original screw is 12mm long the new screw is 14mm long)  I screwed the new in with the gun cocked but( NOT LOADED) till it went off then backed the screw off 1/2 a turn, the trigger is smooth and much lighter suites me fine. :D  :D  :D
Thanks, I have recently acquired a Gamo Compact, and it was useful to read this. I tried a longer screw, but doesn't this adjustment just take up the first-stage "slack" in the trigger movement? And if you continue to screw in, the sears is pushed back, eventually to the point where you can't cock the gun at all.
What I've now done is to lengthen/weaken the short spring in order to reduce the trigger pressure, and I've also added a little grease to the sears. I haven't yet filed and polished the moving parts, but this does sound worthwhile.
Thoughts?
Spiny Norman
Previous
Users browsing this forum: Google [Bot] and 4 guests
