A recent acquisition hissed somewhat when charged with Co2 even when a cylinder known to be good was used. So the culprit was here.
Removing the three cap head screws reveals the primary seal - somewhat squashed & with the elasticity of mahogany.
The old seal,valve spring & the separate head of the valve actuation rod are removed to show the valve chamber & the end of the actuation rod.
Left to right: old & new primary seals; steel valve chamber; old & new secondary seals; valve spring; actuation rod head; rod & return spring.
This is the back side of the valve chamber with the new secondary seal inserted in a counterbore. The little hole engages a stud in the main aluminium frame to orientate the chamber.
All back together again - total time about 5 minutes.
It helps reassembly if the pistol is cocked but don't release the trigger otherwise the actuation rod will be launched into that part of the room where missing parts go.
Russell
