Acvoke
PostPosted: Fri Sep 16, 2016 11:29 pm
by Jeff
Can anyone advise on how to remove the piston from an Acvoke. It seems that the cocking lever (which doubles as the trigger guard) needs to be removed so the piston can slide out of the front but I can't see how the cocking lever is removed.
Re: Acvoke
PostPosted: Sat Sep 17, 2016 12:16 am
by Jeff
Problem solved - take out the trigger mechanism and the cocking arm slides out from a slot just above the trigger.
