Well here it is, the REALLY mysterious East
Postby Tank » Thu Dec 05, 2013 1:22 pm
So, I agonised as to where to put this after Robin's post, but I think here is best because this project has been going on probably (nearly) as long as this forum :shock:
Thursdays I try to get some "workshop time" in and today was no exception. The bits - the Cast if you like (I am sharp today) took a while to assemble. As a couple of you will attest, I am a bit fussy when it comes to materials and I avoid Cr*p like the plague. The velvet had to be a particular type and feel. No rubbish at all.
Then I needed some Melamine faced chipboard and some industrial shrink wrap. Regular household stuff just would not do for this. Plenty of screws and clamps. You can always have too few clamps but never too many in my experience!
Well, a picture paints a thousand words as they say and the following is the equivalent of leaving a hand grenade on the table, with the pin out, Gentlemen, my next trick:
And finally, I do not take credit for this idea, I saw something similar elsewhere and merely adapted it to this.
Re: Well here it is, the REALLY mysterious East
Postby RobinC » Thu Dec 05, 2013 4:12 pm
I think you've confused them even more now Graham!!!
The case is taking shape nicely, but they are probably wondering why you've used a FWB65 as the model for the case? Love the colour by the way!
We watch with baited breath for the emergence of the thing from the dark side to fill the case.
Postby pmh » Thu Dec 05, 2013 5:22 pm
Of course, it is the Chinese copy of the FWB 65.
Titan seems to ring a bell for some reason.
Postby zooma » Thu Dec 05, 2013 10:45 pm
Are you going to make a casket for it out of expanding foam and then give it a funeral on the river Mersey and put it into the water off of the "Daffodil" Mersey Ferry ?
This is a very popular ceremony for our Indian community ( something I have witnessed a few times) as they believe the water flows to and from their home country and so the spirit can eventually find it way home.
I think this is a very good idea and far better than a funeral pile. It is a lot more majestic and the foam will help it float with the tide back to its homeland.
So basically we are going to chuck it into the river - right?
Postby Tank » Thu Dec 05, 2013 11:30 pm
zooma wrote:Are you going to make a casket for it out of expanding foam and then give it a funeral on the river Mersey and put it into the water off of the "Daffodil" Mersey Ferry ?
Perzackly Sherlock!
:mrgreen:
Postby RobinC » Fri Dec 06, 2013 11:28 am
Well now the secrets out, its a Huanqiu FWB65 clone marketed in the UK for a short period by Titan Developments in Birmingham.
The only tests I've seen from the US said it shot smoother than a FWB, and that it was close enough to take FWB spares?
I'll put more details in the pistol section post so as not to clutter this as the restoration.
So how did the restoration go? Did it take FWB spares?
Postby zooma » Fri Dec 06, 2013 12:10 pm
RobinC wrote:Well now the secrets out, its a Huanqiu FWB65 clone marketed in the UK for a short period by Titan Developments in Birmingham.
We encouraged Graham to only use waterproof parts that would float but this was not always possible - hence the use of two-part boyancy foam. :snooty:
This was decided not long after the restoration started - but I can't think why? :think:
.................but notice how close the angle grinder is to the pistol in the fourth photograph! :whistle:
Postby Tank » Sat Dec 07, 2013 4:29 pm
RobinC wrote:So how did the restoration go? Did it take FWB spares?
Yes Robin, the parts are readily interchangeable. As you know I had to make some of the seal kit. The real issue has been the rear part of the trigger sled. For whatever reason someone had decided - in some previous re-incarnation - to enlarge the rearmost part of the sled lock. It is not yet to my satisfaction but it won't take much more.
Direct side by side comparison of the individual components with the original Feinwerkbau item is quite interesting and I will put some photographs up shortly to demonstrate this.
My creation of a new foam insert for the pistol did not quite go as planned but this really isn't a problem, you get a LOT of foam in a tin :mrgreen: I have discovered that the thing to is to cut out a part of the "box" to allow part of the pistol to protrude through. Because of the shape the foam wrapped itself around the pistol as it was expanding.
Great idea but needs a bit of refinement.
Bit of a cockup there but now sorted!
Postby RobinC » Sun Dec 08, 2013 10:31 am
Thanks Graham
Yes, the sledge rear and pin bodge up was what I spotted as soon as I part stripped it and thought Arrrhhhh, this needs parts replacing! I think that was done by a so called local gunsmith who had no understanding of the concept of the design, its so frustrating when these people get their hands on precision target kit and apply blacksmith standards to them.
I'm sure you'll sort it and we look forward to play with it. Would be nice to wipe some smirks away with it.
Postby Tank » Sun Dec 08, 2013 10:56 am
Well Robin, really, my apologies for having taken so long with it.
The end solution was to graft most of what was a FWB trigger unit onto it in the end though now that I have my Mill there are a few tweaks that I will be able to do and it should work reliably every time.
The "Blacksmith" bit. <sigh> I am a bit of a part time Blacksmith myself, I find a morning at the Anvil with a two and a half pound rounding hammer very cathartic some days, though my hands don't think so afterwards :D
I think what people need to do is realise their limitations. To all intents and purposes, when reassembled, it appears that the hole in the rearmost block is in the wrong place. What you can't see of course is that this is all swung upwards and forwards on cocking because it is all enclosed on reassembly. A difference of fifteen thou is enough to cause the mechanism to fail and continued usage of the pistol in this state does permanent damage to some components. I know this from experience unfortunately. I have had a couple of guns sent to me where people have continued to use them despite the obvious fact they are not functioning correctly and parts have had to be replaced. In this case, because the mechanism was circumvented by the hole enlargement, it was malfunctioning yet gave the probable impression that it was working correctly, only to cause further damage.
You need the patience of Job to continually assemble and then dis-assemble them to make minor adjustments - with this specimen I had to continually accumulate that patience, and have a quiet hour or two. Some people of course choose to do Jigsaws :mrgreen:
Next
Users browsing this forum: No registered users and 4 guests
