.20 Cal pellets
A place to discuss and share pictures, reviews, of collectable pellets and tins.
.20 Cal pellets
Postby Mark » Fri Mar 29, 2013 9:32 pm
Does anyone have a source for reasonably priced 20 cal pellets?
H & N and Crosman pellets are well priced for what they are, but a bit expensive to use in my E9A, a £6 tin of Superdomes would be ideal if such a thing existed.
The other thing I thought, was how about making some sort of sizing device to size 22 pellets down to 20?
Mark
Postby pmh » Fri Mar 29, 2013 10:29 pm
Uttings have a selection, and they are quite reasonable on postage if you buy 10 tins, link >here<
Blackpool Air Rifles also have a selection.
You could get a .20 drill bit, or a 5.08mm (5.1mm?) drill bit, if you can find one, drill some steel and try popping some cheap .22 pellets through to see it it works.
Postby Tank » Sun May 05, 2013 8:04 pm
Not quite as simple as that I am afraid. You would need to create a forcing die with a cone from .22 to .20 and then size the pellet by forcing down the cone and through the .20 part.
Easier buying a tin of pellets. Even an expensive tin!
Return to Pellets
