New guy with Webley questions please
Glad to hear you you like your choice of pistol, and are settling in well.
You'll probably obtain dieseling for a tin of pellets at least.
The secret, for me, is to get used to the gun, let it settle in, then try a few different types of pellet through it, to see which group best.
My recommended pellets, from budget, through mid range, to high end are:-
Geco
RWS Hobby
RWS R10
Geco
RWS Hobby
RWS R10
Not got a pdf, but a link to the owners manual, web version, is >here<
You should be able to copy and paste it into a word document.
You only need small turns to adjust trigger, its quite sensitive (16th to 8th turns). Taking the right grip off will be easiest for finding trigger weight screw, I slackened mine one full turn. Theres a slot on the end for the spring to drop into. Top trigger screw is for travel, and bottom screw adjusts for hard or soft release. Its a reciprocal arrangement so turning one affects the other. It can be a bit of a balancing act. If you get messed up, and want to start again, turn both all the way back in, then out again three quarters of a turn as a starting point. ATB. Pete.
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it in a fruit salad. Gamo PR45, P17s, 1377, SMK rifle, HW 40, HW 45, HW 75, Gamo AF10, Hatsan mod 25, Tanfoglio Witness, Crosman 357, Browning Buckmark. Webley tempest. John Beatie holsters.
