I recently picked up a nice (but not mint) .22 "new model" Webley Mark 1 at a very good price and I am more than pleased with it - but it does mean that I am now "on the hunt' for a genuine .177 barrel to fit it so I can use this model to shoot at our regular Thursday vintage Webley shoot-out that takes place towards "close of play" most Thursday nights at RMTC.
The only reason I mention it here is that it ( like Tatty) also has the left hand grip broken
Why is it always the left hand grip that breaks - or am I just a bit unlucky?
So now I need a two left hand grips - one brown for Tatty and one black for the Mark1 - does anybody have any grips to sell or swap that will help me return these two Webley's to their original complete specification?
Webley Senior .177 - "A Little Bit Tatty".
Re: Webley Senior .177 - "A Little Bit Tatty".
"Tatty" was exercised at RMTC last night following her latest strip and rebuild and she shot well and with good power and seemed happy about running on a single lubricant of SAE30 engine oil as all of the grease and dri-slide had been lost during last weeks re-build.
As soon as I got home I took Tatty apart again to see if she was still producing swarf as this has been an on-going worry.
Unfortunately I did find some more fresh swarf on the piston - but this time only in the recess between the head and the ridge that the sear is held back against and none anywhere else.
I cleaned away all of these small steel particles and took out the trigger and sear so I could have a good look around inside and gave everything a good wipe and clean. I polished-up the sear and the sear retaining ring edge with fine wet and dry paper in the hope that this may help prevent any small shards of steel chipping away as I now think this is probably where it is coming from.
I also polished the sides of the trigger and sear so they can slide freely in the frame and checked that there were no new indents in the piston head before putting everything back together again on some fresh SAE30.
As soon as Tatty stops making debris I will grease the spring in the more conventional way but for now I will keep checking after each shooting session until this annoying problem is arrested and continue to use SAE30 oil only as it is much easier to see and clean away any foreign bodies.
Tatty had a little bit too much to drink and made a bit of a scene at the club last night and was asked to leave due to some lurid (explosive) behaviour so maybe only using SAE30 oil as the sole lubricant is OK but its use needs to be a little more restrained.
.........looks like Tatty will come apart again tonight as the weekly swarf count needs checking again and her liquid intake needs reducing - good job she comes apart so easily ( lots of practice) !
We did so using tatty as it was quite clearly detonating after the first few shots.
A such, it was decided to retire for the evening.
A suggestion was put forward to coast suspected areas with engineers blue, or equivalent, to try and identify which surfaces are causing the swarf.
We are nearly there with this pistol, and it will soon be up to scratch.
