Here are some pictures of an early Series Two Junior made just after the war
http://bobsairguns.com/index.php?option ... Itemid=164" onclick="window.open(this.href);return false;
This pistol does not have an adjustable rear sight - even though some of the pre-war Series One Juniors (with the tinplate grips) did have an adjustable rear sight. This abnormality was quickly corrected when the Junior reverted back to the adjustable type very shortly afterwards.
I have shot this particular example of an early Series Two Junior and found when the correct trigger finger position is used it shoots dead straight ahead - only leaving the elevation for the shooter to "adjust" the aiming point to suite.
If the trigger is allowed to creep into the trigger finger joint them it shoots (consistently) to the right.
This is a lovely little 6 yard pistol that really performs well without the need for an adjustable rear sight - very nice indeed.
Here is a later Series Two pistol that does have the more normal adjustable rear sight
http://bobsairguns.com/index.php?option ... Itemid=166" onclick="window.open(this.href);return false;
Note by this time the factory had moved and the pistols no longer bear the "Birmingham 4" post code stamping.
And here is where it all ended with the Junior Mk 11 - the last of the Webley Juniors to be made.
http://bobsairguns.com/index.php?option ... Itemid=167" onclick="window.open(this.href);return false;
The on-going search for cheaper production methods was tested on the Junior Mk11 (and Premier Mk 11) before being used on its ultimate replacement the Typhoon which was a slightly smaller gripped and less powerful spring equipped sister to the Hurricane ( the replacement for the Premier) that also used the same cast alloy construction method.
