Original 6G help
A place for anything general, air gun related, if there isn't already an appropriate sub forum.
Original 6G help
Postby wadcutter » Wed Apr 05, 2017 7:55 pm
My original 6G which I received from my friend has developed a problem. I have noticed on a couple of occasions when I have closed the barrel the pistol has fired but this has only happened a couple of times can anyone help please.
Kevin
Kevin
Diana Original 6G Pistol
wadcutter
Re: Original 6G help
Postby pmh » Thu Apr 06, 2017 1:28 pm
Sounds like the trigger is set too sensitive,
It is a bit of a pain to adjust, as there is one adjustment screw inside and adjustment nut.
I'd tweak it back a little.
Postby wadcutter » Thu Apr 06, 2017 1:53 pm
pmh wrote:Sounds like the trigger is set too sensitive,
Thanks Phil that's a great help I have moved it a touch and all is safe and does not go off while closing the barrel. :D
Kevin
wadcutter
Return to General
Users browsing this forum: No registered users and 6 guests
