I have been getting a bit fed up with cobbling together a suitable rest on which to place my target holder.
I also need a height adjustment depending on whether I am 10m or 6yd.
As such, after a little searching, I got one of >these<
It is rated for 35kg, and a quick hour in the garage resulted in a platform to hold the target holder.
I used this, for the first time recently, for the 6 yard and PIPAS, and it performed very well.
The platform is 12mm plywood, with some drilled blocks for the main support.
Our garden has some uneven areas, and I squared the stand up a little with some wood blocks, but I felt there was little need to overdo this and try to make the stand perfectly level.
This has ertainly made shooting easier, as I can adjust the target to the perfect level for each discipline.
Target Holder Ideas
