Target Holder
Many shooters have made their own target holders, which are perfectly adequate for practice, plinking, etc, but can prove a little problematic when it comes to shooting and scoring official targets.
My own target holder will take up to an A4 sheets of paper, which is held in place with magnets. This works well, but does produce an impact hole bigger than the actual pellet, and it is this that proves difficult when scoring official targets.
There are many makes and style of target holder out there, ranging from a flat plate style to a funnel trap, which guides the pellet into a collection area.
Prices do vary considerably, but the cheaper end tend to be a thin painted steel, whereas the dearer end are a thicker galvanised steel.
They also come in 14cm x 14cm or 17cm by 17cm. It is important to note, however, that competition targets are 17cm x 17cm.
The target holder I had a look at over the weekend is currently on sale through our club.
Front and Side Views
This particular target holder is made from a good thickness of steel, and is galvanised to give it a very long lasting durability.
Fixing
This target holder is very flexible, as it can be wall mounted, using the slotted hole on the back, or left free standing.
Easy To Take Apart
The target holder can be used with the hood down or the hood up, which does control the amount of ambient light that falls on the target face. We are looking at an upgrade which will allow these target holders to have LED lighting in them.
Lifting the hood allows the "strike plate" to be removed for cleaning, and to also empty the used pellets out.
The reverse side of the "strike plate" is shown in the picture above.
Target Insertion
There is a generous sized groove, down each side and along the bottom, into which the target easily slides.
Despite this being quite a generous sized groove, in order to take varying card thicknesses, it holds the thinnest of target cards very effectively.
In Use
Unlike some of the cheaper target holders, the target stays in position, despite constant strikes on the centre.
Initially, I was expecting the "floating" metal plate to make quite a bell like clang, but it doesn't. It does make a short toned clunk, and if this were found to be problematic then a piece of sticky backed foam would dampen this down dramatically.
For me it wasn't a problem.
The idea of the free floating plate is to, obviously, take the energy out of the pellet, and it does this very well.Pellets do stick to it, from time to time, but can be easily removed.
The target holder also traps all spent pellets, plus paper punchings, for easy disposal after the shooting session.
In Use
In conclusion, this is a well constructed, easy to use target holder, offering flexibility for mounting.
Coming in at just under £30 it is at the more expensive end of the market, but you get what you pay for, and this is of a construction that will enable it to last a lifetime.
That said, if enough people are interested, then we may well be able to get a bulk order discount.
Over the next few months I am hoping to do a post on how to install LED lighting in this, and we may well be to offer an upgrade kit.
If anybody is interested in one, then drop me a pm or e-mail.
Fixing
Easy To Take Apart
Target Insertion
In Use
In Use
Re: Target Holder
This looks superb Phil
Looks much better than the thin tin funnel type one Im using that the moment!
I also like the sound of that LED lighting option too - just the thing for the less than perfect lighting in my garage (not to mention my less than perfect eyes)
Put me down for one
Put me down for one
Re: Target Holder
If anybody else is interested in one, then let me know.
There is the possibility that we can reduce the price, albeit slightly.
So far, we have:-
Graham
So far, we have:-
Graham
On a bit of an update, the target holder arrives with a piece of foam, approx 16cm x 16cm x 4cm, which is placed behind the impact plate.
We did think that this was to hold the plate in place, during transport, but a quick reference to the instructions shows this is supposed to be left in place to help reduce "clang".
Oh come on, be honest, who actually reads the instructions straight away!
Anyway, I shall try the target holder with this is in place, and report back on effectiveness.
Re: Target Holder
Absolutely brilliant Phil. This is just what I need to get me back shooting air pistol and entering comps. Do you have a price posted?
Loving the new look btw.
>>>This space has been reserved for a witty signature<<<
Welcome back indeed
Should be able to have a posted price soon.
Re:
pmh wrote:On a bit of an update, the target holder arrives with a piece of foam, approx 16cm x 16cm x 4cm, which is placed behind the impact plate.
Oh Sh*t! I was planning on using that sponge to wash the car with. ANOTHER pound I am going to have to fork out at the pound shop!
Do you think it might dry out and I could use it in the target holder after washing the car?
This is just a disaster!
Re: Target Holder
I fitted the lighting this afternoon, and it works reasonably well.
However, the small gap between the edge of the hood and target is a quite a small width to protect the light through. As a result there is quite a noticeable difference between the light at the top of the target, as opposed to the bottom.
That said, it still works well.
I will try fitting a diffuser to see if this spreads the light a bit more.
I'll post some pics when I get a chance.
Re: Target Holder
Mine arrived today
A most impressive bit if kit - should last for years. I gave it a quick try out earlier - with the supplied foam fitted behind the swinging backstop I had some rebounds, none without and not much difference in noise levels. Quite happy to use it without the foam - as supplied its too thick and doesnt allow the plate to move enough hence the rebounds - thinning it down would work.
I love it - light years ahead of the tin funnel I have already and not that much more expensive - great!!!!
Thanks for getting this to me so quickly Bob
Looking forward to reading about some lighting options
Re: Target Holder
Have we got a posted price yet
Or will they be avaiable at the ubc meet next week
Joe
Joe
Re: Target Holder
I believe postage is £8 on top of the £29.99 cost.
I have seen many target holders in my time, and this is certainly one of the best so far.
These won't be available at the UBC meeting next week.
Re: Target Holder
Would like one of these please! - Quality looks great. Please let me have details of payment.
Re: Target Holder
pmh wrote:I believe postage is £8 on top of the £29.99 cost.
I looked at that then realised. Royal Mail have changed their pricing model into some sort of perverse entity. Over 6"x6"x6" it jumps from £3 to about £8 - caused me no end of grief
