Benchrest Air Pistol - Some Thoughts and a Trial
I spent today having a go on the target, and looking at how to actually rest the pistol.
I chose my Weihrauch HW40 for the trial, and used RWS R10 pellets.
I used the target previously posted.
Proposed Target
I thought the roundals might be too big at first, but at 6 yards the front sight blade of the HW40 is actually wider than the black portion of the target.
As such, I think it is correctly sized.
Scoring
My initial thoughts on scoring is to use the honour system, with upwards scoring.
I have prepared some examples to make sure everybody understands my ramblings.
A Miss
Needs no explaining, a miss is a miss.
Scoring the Bonus
The small centre circle is completely gone.
I was thinking this would be worth 10.5 as opposed to 10 as below.
Scoring a 10
Upward Scoring
This scores an 8
This scores a 6
This is quite standard really.
The "Hold"
I shot two targets, using the HW40 and my Fat Bag benchrest bag.
The first method was to hold the pistol one handed, then to rest the butt of the pistol and my forearm along the length of the bag.
I was sitting, but there is no reason why the shooter can't stand.
I found this very comfortable, with no strain on my person.
I did have quite few "wild" shots thought, scoring 72 out of a possible 105 (using the above mentioned 10.5 bonus method).
I then tried a second target, where I turned my bag sideways, again seated and one handed.
This time, however, I rested the pistol on the bag. The poitn of contact was between the end of the muzzle and the front of the trigger guard.
This time I scored 83 ouf a possible 105, and found this method much better.
As such, my suggestion is that the pistol may be supported at a single point between the muzzle and the front of the trigger guard.
The shooter may, if they choose, also rest their elbow on the shooting platform.
Alternative Scoring
As I never actually completely obliterated the centre circle, we could say that any contact of the small centre circle would score the bonus 10.5
That means both:-
or
would score the 10.5
My highest scoring target is here:-
I photographed it on a red background to try and show up the pellet holes, but they haven't shown up too clearly on each roundal, so I have highlighted the hits:-
However, I do own an Intershoot Eagle Eye scoring gauge, which makes scoring a breeze.
These are a bit pricey, but well recommended.
Gun Categories
Given the distance, and the point of support, I am not sure whether there will be any advantages/disadvantages in choice of pistol, so I would say not to have seaparate categories at this stage.
The competition can always be tweaked in the future if one particular type of gun far out shoots another.
Whilst all this might sound a bit complicated, I think it can be summed up quite simply:-
1 - Shooter may stand or be seated.
2 - The pistol must be shot one handed.
3 - There can only be one point of contact between the pistol and the chosen support. This can be anywhere between the muzzle and the front of the trigger guard.
4 - The shooter may, if they choose, rest their shooting arm elbow on the support platfrom.
5 - There are a total of 10 shots, one at each roundal.
6 - Any roundal with more than one hit automatically scores zero.
And that, I think, is all the rules that are needed.
Proposed Target
Scoring
A Miss
Scoring the Bonus
Scoring a 10
Upward Scoring
This scores an 8
This scores a 6
The "Hold"
Alternative Scoring
That means both:-
or
Gun Categories
Having not tried pistol benchrest shooting I cannot confirm this but it is something I have heard before.zunmik:470 wrote:.......and if you use a recoiling pistol you might find it better to support the wrist or you will shoot high.....M.
Rule 3 may exclude springers if the accuracy is affected by this type of support. Can springer shooters support their wrists instead?
>>>This space has been reserved for a witty signature<<<
Good point.
I think the rule should stand with regards the contact point of the gun and the rest, hand it bring one handed only.
However, I suppose what ever the shooter does with the rest of the supporting arm is up to him/her.
Just need to put this into a simple sentence.
Perhaps: the shooting arm my be held with the none shooting arm, as long as contact is no further forward than the wrist.
I am also wondering if the bonus should not count for .22 as the larger calibre might make scoring this easier. Any thoughts on this?
Of course, we should be using classic guns for this, so wool have to come up with a suitable definition.
Ah, now thats the tricky one!pmh:486 wrote: Of course, we should be using classic guns for this, so wool have to come up with a suitable definition.
I guess its down to defining this by some kind of arbitrary cut off date re year of manufacture and/or design parameters.
How about:
Must be a pellet firer
Must no longer be in production or if currently in production must have been so for minimum of 15 years
This would exclude the modern disposable plastic guns but allow something like a Benjamin EB which although still in production - has been so for decades virtually unchanged. Slightly more contentious would be some of Umarex models - for example I would regard the CP88 (air pistol version of a Walther P88 cartridge pistol) as a classic - others might not!
Yes, I think it is going to be a tricky one.
I thought about age, but guns like the HW70 started in the 70s and are still made today.
One rule I would suggest is:-
All pistols must be pellet firing and single shot only.
This should take care of the mass produced clones.
I'll try and pull some suggested rules together for comment.
