feinwerkbau 100
Azmodan
Re: feinwerkbau 100
Post by Azmodan » Thu Apr 11, 2019 8:13 pm
Mattdale wrote:
I had a similar issue with my 100 when I first got it.
best to strip it down and clean out all the 30 year old grease which can gum up the mechanism.
Also good idea to fit new seals:
https://rover.ebay.com/rover/0/0/0?mpre ... 3092137404" onclick="window.open(this.href);return false;
I used this strip guide, really easy to do :
http://www.airgunbbs.com/showthread.php ... -Model-100" onclick="window.open(this.href);return false;
Very satisfying to have it all as it would have been new, they’re not cheap so worth the effort.
Enjoy!
Cheers,
Matt.
thank you
i ordered a seal set. hope it will fix the problem.
Mattdale
Re: feinwerkbau 100
Post by Mattdale » Thu Apr 11, 2019 11:01 pm
I seem to remember I had an issue with a seized bolt or something when I stripped mine.
I just left the pistol on a radiator for a few hours to warm up and the expansion of the aluminium unseized the bolt. Glad I didn’t try to force it. Other than that very straight forward.
Let us know how you get on.
Matt.
Re: feinwerkbau 100
Post by Tank » Wed Apr 24, 2019 8:08 am
Patience is the magic ingredient with these things, as Matt says, leaving things to soak to loosen up is the way forward. A good clean and re-lube is always beneficial.
