The Hy-score
Posted: Thu Sep 24, 2015 6:30 am
by cinedux
a US-made classic.
http://cinedux.com/the-hy-score-story.php" onclick="window.open(this.href);return false; :roll:
Re: The Hy-score
Posted: Fri Sep 25, 2015 10:52 am
by johnbaz
Hi Cinedux
I have the Brit mk2 version and would love an American one, My bro in law has a U.S. version in very good condition but won't part with it :evil:
I love the pistol and it's 8uite accurate too 8-) 8-)
John :P
Re: The Hy-score
Posted: Sat Dec 26, 2015 7:19 am
by Valther TPH
I have three Hy-Score pistols, each one in .22 caliber.
-Ron
Re: The Hy-score
Posted: Sat Dec 26, 2015 1:32 pm
The multi-shot Hyscore loading system is very interesting, but I have found it takes almost as long to load the magazine as it does to load individual pellets.
Love the feature which allows dry firing without causing damage though.
Re: The Hy-score
Posted: Fri Jan 01, 2016 11:40 am
The barrel looks very short, ar first glance, but I am presuming it is much longer than it appears. Is this so?
Re: The Hy-score
Posted: Sat Jan 02, 2016 12:06 pm
pmh wrote:The barrel looks very short, ar first glance, but I am presuming it is much longer than it appears. Is this so?
Hi Phil.
The Hyscore was a 'concentric' pistol so the barrel appears to be shorter than is actually the case.
The first Series 700 pistols had a 180 mm (7 ") barrel.
The second Series 800 pistols had 268 mm (10.2 ") barrel.
The much shorter, Sporter pistols still had a 199 mm (7.7 ") barrel as did the UK produced Phoenix model.
Although the 700 Series had a longer overall length than the 'Sporter', much of the barrel length was made up of a false shroud .
Happy New Year
Re: The Hy-score
Posted: Wed Sep 14, 2016 3:45 pm
by johnbaz
Hi all
Here are the barrels of my Mk2 sporter, I measured them and strangley they're 196mm, They seem to have lost 3mm somewhere :shock:
John
Re: The Hy-score
Posted: Mon Dec 05, 2016 10:40 am
by john77
I discovered a rather tired Sporter in a local gunshop, some months ago. I have been able to spruce it up quite nicely, but I would like to know if anyone can tell me whether the original type backsight (i.e. with a stepped slider to raise the sight), which is missing, could be replaced with the plastic one shown on some illustrations, or whether I should attempt to replace the original? The foresight does seem rather low if the plastic rearsight is installed.
John
Re: The Hy-score
Posted: Wed Dec 07, 2016 2:03 am
by 45flint
The sights aim the gun high to make up for the action of the piston which moves the barrel downward as it moves in the gun. I actually think the gun barrel may be aimed high instead of the sights, but you get the idea. On the Targ-Aire you can easily see the barrel is aimed downward, the opposite cause the piston goes the opposite way of the Hy-Score.
