Anyone with a link to the S/N lookup for Walther LP53, other
DFWdude
Post by DFWdude » Mon Apr 24, 2017 11:51 pm
I have an LP53. The factory target is dated 18/8/58, and the serial number is 030806. The target indicates 1958 manufacture, but I would like to verify.
Leonardj
Re: Anyone with a link to the S/N lookup for Walther LP53, o
Post by Leonardj » Thu Apr 27, 2017 11:46 pm
According to my info, the date on your test target would be a very accurate representation of the manufacture/dispatch date.
"S/N - 025734 : Jan 1958 through S/N - 033105 : Dec 1958".
The barrel weight would have been a later addition.
I will add the pic that you posted and the serial number to my database. Thank you.
DFWdude
Post by DFWdude » Fri Apr 28, 2017 12:54 am
Thank you so much, Len!
wadcutter
Post by wadcutter » Fri Apr 28, 2017 7:19 am
DFWdude wrote:Thank you so much, Len!
Hi I knew someone on the forum would be able to help you with this query. :clap:
Kevin
Diana Original 6G Pistol
webley701
Post by webley701 » Sun May 28, 2017 7:32 pm
DFWdude wrote:I have an LP53. The factory target is dated 18/8/58, and the serial number is 030806. The target indicates 1958 manufacture, but I would like to verify.
Surely the factory test target date must be the most precise record you'll find for your pistol?
