feinwerkbau 100
Azmodan
Re: feinwerkbau 100
Post by Azmodan » Thu Apr 11, 2019 8:13 pm
Mattdale wrote:
I had a similar issue with my 100 when I first got it.
best to strip it down and clean out all the 30 year old grease which can gum up the mechanism.
Also good idea to fit new seals:
https://rover.ebay.com/rover/0/0/0?mpre ... 3092137404" onclick="window.open(this.href);return false;
I used this strip guide, really easy to do :
http://www.airgunbbs.com/showthread.php ... -Model-100" onclick="window.open(this.href);return false;
Very satisfying to have it all as it would have been new, they’re not cheap so worth the effort.
Enjoy!
Cheers,
Matt.
thank you
i ordered a seal set. hope it will fix the problem.
Mattdale
Re: feinwerkbau 100
Post by Mattdale » Thu Apr 11, 2019 11:01 pm
I seem to remember I had an issue with a seized bolt or something when I stripped mine.
I just left the pistol on a radiator for a few hours to warm up and the expansion of the aluminium unseized the bolt. Glad I didn’t try to force it. Other than that very straight forward.
Let us know how you get on.
Matt.
Re: feinwerkbau 100
Post by Tank » Wed Apr 24, 2019 8:08 am
Patience is the magic ingredient with these things, as Matt says, leaving things to soak to loosen up is the way forward. A good clean and re-lube is always beneficial.
Azmodan
Re: feinwerkbau 100
Post by Azmodan » Fri Apr 26, 2019 2:22 pm
replaced the valve seal (1750.214.1 and 1750.215.1) and now it works ok.
had a bit of trouble removing the old seal and, at the end, putting the front sight cap back on (i could fit it by hand - had to push it in using the screw).
other than that.. all went fine.
Re: feinwerkbau 100
Post by Tank » Sat Apr 27, 2019 8:19 am
All Feinwerkbau's are quality guns. I have a 300S that shoots beautifully and would be the last gun I would sell.
Re: feinwerkbau 100
Post by zunmik » Sat Apr 27, 2019 11:03 am
Fully concur with the comment that all Fwb are superb, whilst shooting i always wanted, but never found the rare RB version though i was rubbish @ running boar with my 300. mike.
S.G.S Duo 300,Etc, G0JVB ex G6MUI.
Azmodan
Re: feinwerkbau 100
Post by Azmodan » Thu May 23, 2019 5:39 am
a presentation video for fwb100:
