Acvoke
Jeff
Acvoke
Post by Jeff » Sat Sep 17, 2016 12:29 am
Can anyone advise on how to remove the piston from an Acvoke. It seems that the cocking lever (which doubles as the trigger guard) needs to be removed so the piston can slide out of the front but I can't see how the cocking lever is removed.
Jeff
Re: Acvoke
Post by Jeff » Sat Sep 17, 2016 1:16 am
Problem solved - take out the trigger mechanism and the cocking arm slides out from a slot just above the trigger.
