Webley Tempest
Posted: Mon Nov 11, 2019 2:56 pm
by guitarist
I've recently acquired a Birmingham made Webley Tempest and would like some advice on lubrication points and recommended lubricants. Thanks in advance....
Stephen.
Re: Webley Tempest
Posted: Mon Nov 11, 2019 9:06 pm
by bellringer
In all honesty I wouldn't lube it much at all. The piston head doesn't really need it, and most pivot areas have enough clearance not to be a worry. However if you want to lube pivot points, use a light moly oil from a reputable gun shop; do not use a basic silicone oil, it 's not an actual lubricant and will cause wear on metal joints; oil very sparingly but again not in the cylinder.
Re: Webley Tempest
Posted: Tue Nov 12, 2019 5:05 pm
by guitarist
Thank you for the advice!
Stephen.
