please help.............
hello fellow webley fans,
i recently acquired a webley straight grip mk.I and I am trying to find a replacement sight blade for it. as you can see from the attached pics, the one which was on it has been a little ‘butchered’ over the years. the condition of a replacement is not that important as long as it has not been filed or cut down.
thanking you in advance for any help you can offer.
andyL
andyL
Re: please help.............
This should be relatively simple to make.
I'll have a chat with Graham.
thanks phil. ideally i would like to track down a used original, but........................
You are like me.
However, in the event of a replacement original not being available, I have fitted a copy part and kept the original to pass on with the gun should I ever so it.
phil, you are a gent. i would appreciate any help you and graham can offer.
most respectfully,
andyL
most respectfully,
andyL
If you get a moment could you jot down some dimensions?
- Marksman
Hi, from bellringer. I have a new Mk I rear sight blade which has some surface rust due to not being stored properly at some point,but it has not been used. PM me with an offer [inc post]; not too sure what it's worth but will consider whatever you offer. Hope this helps. bellringer
