6yd MPL Results Jan, Feb, March 2014
Postal competitions using spring, SSP, or MSP air pistols, that can be shot at home or in a club.
Thirdwheel
Post by Thirdwheel » Sat Jan 11, 2014 5:42 pm
Hello all you 6yd traditonal pistol target shooting enthusiasts.
Here is where I will post results as they come in, I've tried in vain to post a table be it excel or any other type, so I will do my utmost to make it clear as possible in the way I do post it. I will also email you the results table in an excel spread sheet as I update the scores.<6ydmpl@gmail.com>
Don't forget send all results to me at <6ydmpl@gmail.com> but remove the <>!
"Thirdwheel"
Spring series: If you click on graphic below it will enlarge and is easy to read!
Adam77K
Re: 6yd MPL Results 2014
Post by Adam77K » Sat Jan 11, 2014 6:49 pm
Just tried to do a BBCode table but it didn't render. The following should have worked:
[table]
[tr][th]Heading 1[/th][th]Heading 2[/th][th]Heading 3[/th][/tr]
[tr][td]row1 col1[/td][td]row1 col2[/td][td]more stuff in col 3[/td][/tr]
[tr][td]row2 stuff[/td][td]more stuff in row 2[/td][td]blah blah[/td][/tr]
[/table]
The forum software may not support BBCode tables.
The alternative is to wrap it all in code tags so it is in non-proportional font and the spacing should be easier.
Code: Select all
[code]formatted table here
[/code]
So you should be able to get something like this. It might be easier to edit it in notepad so you can see the spacing in its fixed font, then copy/paste the table into the code tags
Code: Select all
Heading1   Heading2   Heading3
12345678   12345678   12345678
HTH
Adam
Post by pmh » Sat Jan 11, 2014 6:52 pm
I used excel on my laptop, then reduced the view to 65%, took a screen shot, then cropped the table which I saved as a jpg.
This seemed the easiest way to update the data.
Thirdwheel
Post by Thirdwheel » Sun Jan 12, 2014 5:47 pm
OOOH
Great info, will mess about with it and see what a knot I can get myself into!!!!!! but posting in plain text till I perfect it. I did have a go at pasting a screenshot but will revisit it.
Best cheers
George
Thirdwheel
Post by Thirdwheel » Sun Jan 12, 2014 6:12 pm
Had a play and it seems to work but needs some formatting at excel level to look better. Adam I will get our IT chaps to walk me through your method as I'm more of a wood and metal basher!!!!
Best cheers
George
Post by pmh » Sun Jan 12, 2014 7:34 pm
Thirdwheel wrote:Phil
Best cheers
George
I can let you have the spreadsheet I used for the last comp if you like.
Thirdwheel
Post by Thirdwheel » Mon Jan 13, 2014 7:54 pm
Thanks for the offer Phil, I've built a spreadsheet that works fine it is just the graphic appearance that I've not tweeked as of yet as I'm in the middle of marking mock exams at the moment.
Many thanks again
George
Thirdwheel
Post by Thirdwheel » Fri Jan 24, 2014 7:12 am
Results updated
George
Thirdwheel
Post by Thirdwheel » Wed Jan 29, 2014 11:12 pm
Hi trad pistol shooters
Get those cards shot and get the results to me. do not worry if your scores are low to start with as with practice they improve and it gives you a real reason to get those pistols out and being used. I started in the last series scoring 14 now I'm annoyed if I do not score over 36 per card.
hope you are not having to dodge the weather to shoot
George
Thirdwheel
Post by Thirdwheel » Sun Feb 09, 2014 10:42 pm
just to remind everone the email to send your result to is <6ydmpl@gmail.com> but remove the <> first
Best cheers
George
